Intermittent Heat Problem
Hey everyone,
Did search, but no avail. I have this really bizarre intermittent problem with my heater. It comes up when the engine's at normal op temp. I usually set it to a nice, comfortable 72-73 degrees, with the A/C constantly on. On a slight incline, the heat just completely dies and all I get is cold A/C air. If I crank the sucker to full heat (past the detent), the heat comes back, but if I move it back to 74, it'll blow cold air.
Then, 30 seconds later, it will work just fine. I thought it may have been air in the cooling system, but I've bled the sucker.
Could it be the infamous sword?
3/90 production, so no cabin air filter.
_______________________________
1990 535iA Glacier Blue Metallic 114k
