Results 1 to 8 of 8
Thread: Korman / mosselman turbo setups?
    Central NJ - USA
    Default Korman / mosselman turbo setups?
    http://www.mosselmanturbo.com/index2.htm
    http://www.kormanfastbmw.com/turbos.htm
    http://www.kormanfastbmw.com/e34.htm
    they (mossel) claims 260hp and 425NM for his
    535i turbo setup. what do u guys think? anyone
    have this/try this?
    i know pat p in FL has his own custom twin turbo
    setup, but to be honest i haven't seen ANY other
    e34 turbo setups. jon k said something about turbo
    chargin his 525 but again, custom turbo system.
    i'm interested in a kit form, all i need and some
    instructions =]
    Default Look here: http://www.turbochargingdynamics.com.
    They've been developing an interesting setup for the m30.
    erased due to slander
    Matt Guest
    Quote Originally Posted by Martin in Bellevue
    Unregistered Guest
    Default mossimo
    go with mossimo..exclusively @ Target
    Renton, WA
    260hp is easy to believe, that's only 50hp more than a stock engine makes. The lower compression M30 variant in the E23 745i turbo (M102 or M106) makes that with 8psi and a small intercooler.
    I'd think on a later M30 you'd be up around 300hp with moderate boost.
    1992 535i TCD-s2
    Central NJ - USA
    yeah i noticed factory compression is 9:1 that is good for
    running low boost.
    what about the internals? are they smooth, or could they
    use some work to keep the turbo air flowing nicely?
    Default Korman Turbo
    I seem to recall that Korman had there own custom turbo system. When did they switch to Mosselman?
    Central NJ - USA
    i'm not sure but on thier site they say that they use the mosselman setup and add thier own components or some such space filler
    so are these the only options then?
  1. What's the 'pucking' deal? -Clutch setups in depth-
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 04-03-2009, 03:50 PM
  2. Mosselman Turbo Kit BMW -- E36 318i/is/ti or Z3
    By RockJock in forum 3 Series BMW
    Last Post: 06-01-2007, 11:18 PM
  3. Korman Cams
    By acidfire52 in forum 5 Series BMW
    Last Post: 11-21-2006, 07:10 PM
  4. Complex question about e32/e34 rear brake setups...
    By genphreak in forum 5 Series BMW
    Last Post: 05-29-2006, 07:32 PM
