Originally Posted by
pcross
Here's a curious tranny problem. 1994 525i, A4S27/310R tranny. When I start the car, dash light shows E P. Goes into reverse and backs up just fine. When I shift to D, nothing. If I rev the engine a few times, the tranny engages and the Trans Program light comes on. I then shift to L and it goes into 1st gear. I move off and shift to 2, it shifts. Then to 3, it shifts to 3. then to D and were cruising along in 4th gear, 60 mph at 2300 rpm. Runs like a dream. As I slow down to a stop, I down shift to L and start all over again. OR, when I start the car, I immediately move the MODE switch to M. Then, it shifts and runs in M D mode just great... 1st, 2nd and 3rd. Settles into 3rd at speed, 60 mph at 3300 rpm. I think I have a 2nd/3rd or a 1st/2nd/3rd/4th solenoid valve problem in the tranny. I switched the EGS unit to a new one and the switch made no difference. Tranny has new filter and was properly filled. BTW, all shifts are smooth as silk. No clunks, no jerks. The tranny itself performs flawlessly after I go through all the steps I listed above. Any ideas? Thanks.
