Results 1 to 9 of 9
Thread: valve cover gasket
    Wake Forest, NC
    Default valve cover gasket
    I noticed some hesitation in my 94 525i, so I decided to pull a plug and have a look. When I removed the #1 coil pack, I saw a decent amount of oil pooled up in the bottom of the hole. It looks to me like this is coming from the rubber seal near the top of the recess for the spark plug. I'm guessing this is the valve cover gasket. Has anyone had a similar experience? The gasket job doesn't look to daunting. That's one of the things I love about a straight 6 motor. Things are generally very accessible.
    Wolfpack
    1994 525i
    Eastern NC
    Jan 2008
    Quebec, Canada
    Quote Originally Posted by wolfpack
    Had the same problem, the seals are dried up, super easy and straightforward to change the gasket.
    The whole cover comes on with a 10mm Socket , Short Extension and Rachet.
    BMW E34 1992 525i Touring
    Oldham, England
    Quote Originally Posted by bad_manners_god
    ... and a rag to stick down the open plug hole so you dont drop bits in...
    croatia, zagreb
    i changed the gasket recently, it's about an hour work, just be careful not to drop any screws, the screws near the firewall are irritatingly inaccessible.
    Nov 2006
    Germany
    Where's the best (read - cost effective) place to get the gasket?
    I think I paid around 30 euro for the gasket set and a bag of 25 grommets that seal around the valve cover nuts at the local dealer (Germany).
    As the valvecover nuts are designed as a positive lock system (can only tighten so much, won't over-compress the gasket), the grommets must be tall (not old and crushed) to apply the proper pressure on the valvecover to seal the valvecover gaskets.
    The worst part of the job is peeling apart the plastic housing that holds the ignition and fuel injectors' wiring harness.
    I used a speed wrench and regular 10mm socket or the speed wrench and a long extension with a 10mm universal socket on the end for the lower firewall-side nuts.
    Brian
    Dec 2006
    i got mine at BMA for a good price.
    Wake Forest, NC
    Wolfpack
    1994 525i
    Eastern NC
    Jan 2008
    Quebec, Canada
    Any automotive parts store, just shop around, defiently not dealer. I paid $40 for mine awhile back, but that's garage price.
    Feb 2008
    909 IE
    I just found out i need to change my gasket also. but mines need to gaskets well that what i get for have an M60
  1. Re-use valve cover gasket?
    By bsell in forum 5 Series BMW
    Last Post: 02-03-2008, 01:40 PM
  2. valve cover gasket job
    By pheno in forum 5 Series BMW
    Last Post: 09-03-2007, 06:57 AM
  3. 95 525 Valve Cover Gasket
    By Scott C in forum 5 Series BMW
    Last Post: 09-07-2006, 10:53 AM
  4. Help! Doing Valve Cover Gasket
    By 530iBall in forum 5 Series BMW
    Last Post: 08-26-2006, 11:50 AM
  5. Valve Cover Gasket
    By Shaun in forum 5 Series BMW
    Last Post: 03-12-2004, 01:09 PM
