Anyone know which solid rubber mounts can be used instead of the oily ones??
Didn't know there was an option.
BavAuto, BMA, & Pelican all show one style.
Don't mess with what factory gave you. V8 engine we have is inheritantly a rocker due to peaky cams installed. So if you stuck a solid rubber there, your car will shake like an oversized dildo.
That means something else is broken that allows excessive engine mount movement. What brand of engine mounts did you use?
I have tried 2 times now, that the factory ones crack and I have oil all over the bottom of the engine/car. That is why I wan´t solid ones.....
It was on 2 different cars, so I just think the engine mounts were old.
Never, ever can that be from the mounts. That must be a different oil/fluid. Look here how small the amount is in that space, pic from Gale from a cut-off mountOriginally Posted by Jan
http://www.nmia.com/~dgnrg/mmount.jpg
