I use 50% or a bit more coolant. For track use plain water transfers heat better, there are also additives like Water Wetter to improve even further.
I have ocassion to work on real race cars and they all run plain water.
I am curious to find out what water to antifreeze ratio you guys run in winter vs. summer if any difference at all. Also I am looking for suggestions for when I go to the track.
Conforti chip, K&N filter, Racing-dyn sways, EBC pad/rotor, SS brakelines, UUC DSSR, custom sound+alpine receiver, 17" PS2s, H&R/bilsports.
"Speed is the product of doing everything right"
By plain water do you mean distilled?Originally Posted by Ross
If you are going to mix it and leave it in distilled is recommended. In the race cars it's whatever comes from the local tap.
Would that be ok/ideal to do on my car for the track?Originally Posted by Ross
Unless it's a dedicated race car just use a 50/50 mix. A well functioning stock cooling system is adequate.
your brakes will fry before the cooling systemOriginally Posted by healtoeit
Gone but not forgotten
I use 50/50 here and it gets to be -40 C in the winter, don't have any issues.
WhatOriginally Posted by dacoyote
50 / 50 with bottled (gallon) spring water
I miss my e34
