Results 1 to 9 of 9
Thread: Custom fuel rail is done!
    PA
    Default Custom fuel rail is done!
    Long story short - I bought a Ross Machine Racing BMW fuel rail a while ago when I was first starting my build. It is a nice rail made from -6 AN aluminum extrusion. As my build went underway and I kept building up the engine and parts for a lot of power, I realized -6AN may not be ideal for the fuel flow I intend to run.
    A lot of big HP guys run -8AN but the only readily available -8 AN rail is a PPF unit from Sweden. So I started looking into making my own. Found that Ross sells -10AN extrusion for $12/ft. So I sold the -6 AN with fittings for a bit of a loss, but the cheap raw extrusion would make up for it.
    So anyway, we went and copied another -6 rail I had in terms of fitting size and bore depth. This is a huge rail capable of flowing more fuel than I could ever want. Its nice to not have to worry about choking on fuel flow. All my lines are -10AN and the rail is -10AN and everyone is happy.
    We also tapped the center of the rail for a -4 AN feed directly to the nitrous solenoid. So instead of T'ing the fuel line all sloppy, we tap the rail and its a nice neat tidy package. I'll shut up and post some pics!
    Old rail size vs new rail size:
    I am pumped - and also, my motor should be done in the next few days!
    Jon
    Wellington,New Zealand
    the 10 AN looks like a 45 colt.....
    Gone but not forgotten
    kingsbridge, devon, uk
    that looks damn good
    PA
    Thanks guys!
    Inner diameter of -10 is .625"
    Dunlap Illinois
    Anybody want to invest some stock in Tire Rack with me??? =)
    Good work Jon, well done. Hope everything goes smoothly for you. Are there any modifications to the drivetrain and clutch to keep them from exploding when you "tap" the pedal? How about stopping? You got a chute? =)
    JR
    PA
    Those are only 65# - they are not mine they are for a friends car, I used them for fit up though.
    PA
    Quote Originally Posted by Jr ///M5
    JR
    haha - just a standard flywheel for now (might change my mind later) and a 4 puck clutch. I am going to be making a driveshaft hoop. No chutes This is a street car - as soon as the car is running and all the kinks ironed out, I am going to be making adapters to fit wildwood 6 pot calipers on the front with a big disc.
    Jan 2008
    Quebec, Canada
    Whats the flow on those injectors?
    BMW E34 1992 525i Touring
    Bay Area, CA
    well done.
    Greg Mannino
  1. Fuel rail pressure?
    Last Post: 11-01-2009, 12:11 AM
  2. I Have Fire And Fuel To The Rail But Won't Start
    By clarkstreet in forum 5 Series BMW
    Last Post: 02-03-2009, 05:37 PM
  3. HELP! can't get fuel pressure regulator out of fuel rail....
    Last Post: 01-21-2007, 09:26 PM
  4. Fuel line to fuel rail, pipe bursts
    By Mozarts_Ghost in forum 5 Series BMW
    Last Post: 04-14-2006, 12:52 AM
  5. Fuel rail and injectors
    By jj7 in forum 5 Series BMW
    Last Post: 04-04-2005, 08:40 PM
