Thread: Water Pump - 95 540
    Apr 2004
    Default Water Pump - 95 540
    Hi All.
    I'm changing my water pump and can't figure out how to break the 27mm vibration-damper-bolt. Any suggestions would be appreciated.
    Thanks, Doug.
    That's easy... use a breaker bar.
    Apr 2004
    I should have been abit clear, how can I break the bolt (with a breaker bar) and keep the crank from turning.
    Thanks for the reply.
    Try with all your belts attached and tensioned.
    Default You don't remove the 27mm bolt, you take off the smaller bolts around the hub and
    the damper comes off leaving the hub... then there's enough clearance for the water pump
    Thanks, Doug.[/QUOTE]
    Apr 2004
    Thanks much Bill! That's what I thought from the Bentley but the damper won't come loose. I didn't want to bang the hell out of it if it was still being held by that large bolt.
    Now I'll try to figure out how to pop it off.
    Doug.
  1. Water Reservoir Clogged, Water Pump Leaking?
    By kelhami in forum 5 Series BMW
    Last Post: 04-28-2008, 03:01 AM
  2. Small water pipe came out while doing water pump
    By merlin in forum 5 Series BMW
    Last Post: 09-27-2007, 06:11 AM
  3. Wtf?! Water Pump?
    By nirvana19 in forum 5 Series BMW
    Last Post: 09-23-2007, 04:47 PM
  4. m50 water pump?
    By Ross in forum 5 Series BMW
    Last Post: 04-24-2006, 01:14 PM
  5. water pump
    By joe maniqz in forum 5 Series BMW
    Last Post: 10-31-2005, 07:32 PM
