Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Replace A/C system, 134a upgrade information
    Houston TX
    thanks for info......
    Philippines
    Ok, I'm still running the original R12 system... but just in case my compressor dies... what do I have to change to go R134a?
    Are all I need the retrofit kit and a new R134a compressor? Everything else stays the same?
    baton rouge, loserana
    to do a retro on a running system, i drain the compressor of oil, replace the dryer and expansion valve, while the system is apart i blow as much oil from the system with shop air as i can, (now that i have a flush gun i flush the evap and condensor with ac flush solvent, $125 from napa for the gun/tank and a gallon of flush, i use a 1/2 pint at a time it's $50 a gallon) replace the fittings with quality steel fittings with their own valves not those shitty aluiminum ones that use the old valve, the good ones you remove the core from the old fitting before you screw on the 134 fitting on, refill the compressor with about 6 ounces of ester ac oil and vaccum the system down for about a half hour and charge with 3.4 pounds of r134
  1. exhaust system sort-of upgrade
    By BennyM in forum 5 Series BMW
    Last Post: 06-23-2009, 02:43 AM
  2. Susp Advice - replace or upgrade?
    By Dave Rutkowski in forum 5 Series BMW
    Last Post: 06-18-2009, 01:58 PM
  3. Site Outage To Upgrade System
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 12-20-2006, 07:48 PM
  4. new information on aftermarket stereo upgrade?
    By everlast in forum 5 Series BMW
    Last Post: 10-16-2006, 10:53 AM
  5. Remus Exhaust System upgrade
    By MTMnet in forum 5 Series BMW
    Last Post: 07-16-2005, 01:02 AM
