Most likely a pulley/tensioner bearing on its way out. I've had a tensioner get quite noisy. I don't believe theres much chance of a fan clutch squealing as its a viscous coupling.
Dave M
I sometimes have a squeal that comes from the fan belt area. Is it most likely the pullies/tensioners or fan clutch. It happens more when it is cold, so maybe it's the fan clutch before it tightens up? Anyone have either or both of these fail?
Dave M
x1. Check if it squeals when you put on fan, heated screen, headlights etcOriginally Posted by Dave M
I'll bet your 525 is an M20 without belt tensioner and the belt is loose.
Let us know some details and we are better able to help.
