Okay, so this happened on my last E34 - the A/C compressor seized and the clutchpack died in a shower of molten plastic.
However... I'm getting a smell from under the bonnet that started when I switched on the aircon yesterday to defog the front windscreen. The A/C could be heard to 'clunk' in and then 'clunk' out again putting load on the engine at idle.
Pretty much straight away I was getting the smell of burning plastic and/or the smell of burning electrics.
Out of curiosity I unlocked the OBC and ran the voltage check - I was getting (bearing in mind windscreen wipers, rear demister, fan and headlights were on) about 12.4-12.5 volts (idle) 14.5-14.8 >2k RPM
Now I know the v8's idle really low, so it doesnt really surprise me that much - it would rebound to 13.8 at idle unloaded. Does anyone know if these figures are correct?
Next question! Is the 540 fitted with an auto tensioner on the A/C belt? could it just be the burning smell is the belt slipping rather than the clutch pack starting to self destruct?
Any pointers would be really helpful guys
EDIT: would running the compressor with no gas cause it to seize up?
