Results 1 to 8 of 8
Thread: Fused Jumper Wire with On/Off switch...
    Jul 2007
    Muskegon, MI
    Default Fused Jumper Wire with On/Off switch...
    Hopefully this will help those newer do-it-yourselfers:
    While doing some recent fuel pump work I was reading in the Bentley about the testing procedures and ran across the mention, and the need, to have a Fused Jumper Wire with an On/Off switch.
    So I hit five local auto parts stores, RadioShack, Sears, and a local electrical contractor supply store looking for one.
    I got a blank stare each time I asked.
    So I figured it can't be that difficult, so I went about making my own and here's the result:
    The whole thing cost about $10 US, but it took a bit of time running to different stores to get the different parts.
    Here is the Detailed explanation with what part is what:
    Wellington,New Zealand
    nice work with the switch and post!
    I wish I could handle a PC so good to make such nice instructions.
    Great diagram, a picture is worth more than 1000 words sometimes.
    Thanks!
    Bay Area, CA
    Its a great diagram, you should write repair manuals.
    Anyways, why would you want a switch on a fuse circuit? I cannot think of any reason why you would want to shut down an entire circuit at once?
    Greg Mannino
    Jul 2007
    Muskegon, MI
    Default Reason for the switch...
    Quote Originally Posted by gmannino
    As Bentley's states..."To avoid fuse/relay panel damage from repeated connecting and disconnecting, also include a toggle switch."
    In my case, testing fuel pump issues, you pull the fuel pump relay and plug the jumper into the slots for terminals #30 and #87. With the switch you can control the test better and not engage the pump test until you're ready.
    Jul 2007
    Muskegon, MI
    Default Thanks...it's my job...
    I'm a creative director at an ad agency so I make images and layouts on a regular basis...so I can feed the kids and repair the bimmers.
    I'm just glad to be able to use the skills to help out here and contribute.
    Twins!!!
    Oh, now that I look at yours again, mine is definitely the ugly twin.
  1. How to make a oil and service reset jumper
    Last Post: 05-02-2010, 02:31 AM
  2. Car won't start: tried a jumper on the relay, next!?
    By Monastie in forum 5 Series BMW
    Last Post: 05-24-2008, 06:29 PM
  3. Replies: 6
    Last Post: 05-13-2005, 09:03 PM
  4. Replies: 4
    Last Post: 01-04-2005, 08:32 PM
  5. Replies: 3
    Last Post: 07-08-2004, 09:49 PM
