Results 1 to 5 of 5
Thread: Passenger Low Beam Out (Not bulb or LKM)
    Connecticut, USA
    Default Passenger Low Beam Out (Not bulb or LKM)
    Hey all, recently my passenger low beam decided to stop working. My LKM has recently been re-soldered, and I just replaced both low beam bulbs. I had been running HIR bulbs modified to fit but just replaced them with standard 9006.
    Still not working, I see no obvious wiring issues, anything I am missing?
    - Jeremy
    1990 Islandgrun 535iM Sedan
    3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
    Jun 2006
    Bethesda, MD
    Double check the fuse, easy to miss. Else its the LKM, mine worked for a while after re-soldering then I lost one low beam. Replaced with another and then replaced the fuse and it worked (old one started blowing the fuse for some reason and that side didn't work at all, trashed it).
    Oldham, England
    Quote Originally Posted by ILoveMPower
    - Jeremy
    Even new bulbs can be duff. Try swapping the suspect one for the good one on the other side. Or using a DMM see if you have continuity across the bulb. While you have the meter out, check you have 12v and earth at the bulb. If no 12v, check fuse - a blown bulb can take the fuse out when it goes. After that trace back to relay.
    Wellington,New Zealand
    there is(are) more than one fuse for the lights too
    Gone but not forgotten
    And the are 2 out contacts from the relay for low beams. Maybe one does not work inside the LKM.
  1. Passenger Low beam not working
    Last Post: 04-25-2007, 07:54 PM
  2. Low Head Beam Bulb
    By rufryder in forum 5 Series BMW
    Last Post: 02-04-2007, 04:15 PM
  3. How to remove main beam bulb holder?
    By skeggysteve in forum 5 Series BMW
    Last Post: 01-23-2007, 04:43 PM
  4. Best Brand low beam 9006 Bulb
    By ThoreauHD in forum 5 Series BMW
    Last Post: 04-19-2006, 09:35 PM
  5. 2001 525 XEON low beam bulb replace
    By markone in forum 5 Series BMW
    Last Post: 12-03-2005, 11:02 PM
