failing pump, filter, or FPR maybe?
Got a call from a friend, and this is what he's got.
95 525 iT
Cars runs rough, stalls and backfires.
He's changed the plugs, but they get fouled quickly.
I recommended he check his ICV and MAF.
what do you guys think?
Backfires at intake or exhaust?
Fouled plugs lead me to think something more serious than say a vacuum leak. Valve timing, flat cam?
clogged cat ?
Originally Posted by Ross
out the back...seems real rich
Weak ignition perhaps, valve timing.
Hope he gets it sorted that's a mighty expensive muffler to blow up.
It might be a big vacuum leak at intake: It might be the connector in the back of the intake manifold. Clip of connector is broken and connector slipped out.
Connector which connects manifold and Idle control valve.
I had this problem. Martin
