I took off the coolant level sensor to replace it and the radiator coolant emptied out...
So I installed a new one and filled the radiator with coolant... I tryied bleeding the radiator like the bentley manual. with no success. I even had the front end up on ramps... I have bleeded the system in the past with no problems. This time I am having a hell of a time... I have spent several hours trying...
Does anyone have any tricks or suggetions... Should I empty the radiator and start all over??? The aux coolant pump buzzes... I guess there is air in it.... I got it to stop but than after bleeding and coolant spitting out of radiator it started to buzz again..
I noticed that this new rad bleeder valve does not have a notch cut out. It is solid all the way around... So the only way to bleed it to take it almost all out... The only thing I get out of it is steam. Is that right????? I am just so pissed.... anyways.... Any help would help.... thanks in advanced...
