Ignition goes to run but not all the way to "start" position? Key is apparently blocked from going to "start" position. Thought it might be blocked in the switch, as opposed to the lock assy. Pulled switch. May not have gone to start position on first few tries with small screw driver in the slot but then it works every time. Reassembled switch to lock assy. No luck.
Key goes to start position OK when switch is not installed.
Wife now using remote starter switch rigged into car to start. She's proud and wouldn't usually tolerate a lashup but she is damn tired of horsing the suburban around at Xmas, and I have been stymied by the problem.
Found this in the old '95 "Technical Finesses" thread.
JoshsE34-M50 JoshsE34-M50 is offline
91 525ia 129k
Default No starter grinding.
Cool feature- once the car is started, the ignition switch can't be turned foward into the "start" mode again- so the flexplate gear can't be ground by the starter- good if someone else has to drive your car for whatever reason.
Could this be my problem???
