Later model E34s have the right arm, just pull one from that.
Where can I purchase a wiper arm and blade replacement for my 89 535 (drivers side USA)? I found the passenger side no problem at the local parts store but the drivers side is not available.
EuroLux:. Private Detail
As you have all the nice tools available and like working on modifications, how about Bosch Aerotwin ? The ones fit from Renault Laguna
Orginal Bosch AeroTwin for the Renault Laguna Rfers to E32, so check for E34.
Orginals are in Europe for E32 60cm & 60cm, AeroTwin for Laguna have driver side 60cm & passenger side 50cm.
For that you have to cut the upper piece of the wiper arm and reweld it again the reverse side, then it will fit.
Some pics from Germany E32 forum
this Aero is from Ford Ka, no chnages were made
http://img443.imageshack.us/img443/9643/img6032az9.jpg
modified
http://neukaemper-partner.de/BMW/w1.JPG
and installed on driver side
http://neukaemper-partner.de/BMW/w2.JPG
passenger side, at that time not yet 100% fitting
http://neukaemper-partner.de/BMW/w3.JPG
http://www.7-forum.com/forum/5/ferti...her-49820.html
try BMA in Ca.
Why on earth did they design the arms with opposite curls. Thats like nuts. So all I have to do is cut the arm flip the curl and reweld it? Then the wiper that fits on the passenger side will fit on the drivers side too? Wow what a saturday project.
Oh by the way I found nexen tires here in the USA but I have to order them from Florida $60.00 USD and free shipping. The only tires I could find that would fit the P225 60R15 were the CP641
http://www.unsertire.com/detail.aspx?ID=25006
I don't know much about this tire but it is all season and has a H rating. Sounds good enough for me
The only other option I had was the N2000 and that is too short a life for a tire
before you cut the arm, check the wiper arms first, the pics I posted are from E32 7 series, not sure if that is the same on the E34. Also check what wipers you could get, I assume the Renault and the Ford Ka are not available where you live.
Holy cow $89.00 =-OOriginally Posted by Russell
Results sorted by PRICE (Click on heading to re-sort)
Click back to modify your previous choice.
Most prices do not include extended warranties or shipping.
Not all displayed parts are interchangeable. Please verify with the recycler that the part fits your auto.
here are about 30 listed between 15-25$
http://www.car-part.com/
you can select search by area, price or whatever you want.
That is the best search engine in USA
Hey this is pretty cool
