I think the quickest and easiest way is to lift the engine from the top and lower the subframe. You'll have to pop the universal joint on the steering column off of the box to make this work.
Might want to check the oil pump sprocket nut while the pan is off. I wouldn't weld it, but loctite or one of the safety wire solutions might work...
