Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: I need a Tool to pull the Steering Wheel?
    May 2006
    NH
    Default I need a Tool to pull the Steering Wheel?
    When at the local BMW parts counter the other day getting a 1.5 watt bulb for the Inst.Cluster the parts guy said I'd need a puller tool to get my steering wheel off. This is news to me. I have a 22mm socket and a tube of red lock tight and thought I was good to go. What was he thinking?
    1995 540i Manual build 1/95
    No need, but you have to switch ignition on, otherwise the pin inside blocks the removal.
    http://bmwe32.masscom.net/sean750/da...usterBulbs.htm
    Just pull straight and wiggle it, then it will come out. But do not forget the ignition.
    May 2006
    NH
    Does the battery need to be conneceted for the ignition to disengage the lock then I disconnect the negative cable before undoing the SRS plug or can i turn the ignition with the negative cable disconnected? Thanks for the facts.
    Nov 2006
    No need to have the battery connected to disengage the lock.
    Just take your time and be careful.
    vince
    Quote Originally Posted by Jehu
    Nov 2006
    Maryland
    How do i go about taking the steering wheel off a junked car?
    no power and locked steering wheel
    Quote Originally Posted by ///Sniper535
    That is bad luck, I can tell you from experience on my own 750 E32 parts car. I forgot that this pin stuck inside the steering wheel and pulled and pulled, did not come off.
    Then I remembered that the pin has locked it. Luckily I found a spare key of the car in the tool box in the trunk
    That is with the 'key' in
    http://bmwe32.masscom.net/johan/dash...nt_cluster.jpg
    and that is how it looks with locked steering wheel, you see the pin out
    http://bmwe32.masscom.net/johan/dash.../nightmare.jpg
    http://bmwe32.masscom.net/sean750/da...ardsColumn.jpg
    You might have to remove the lock first completely, but not sure.
    Nov 2006
    Maryland
    bad times...
    Disconnect the battery. If the ignition is on with the airbag off or the cluster disconnected it will set the SRS warning light.
    I don't recall needing to turn the ignition on when removing the wheel.
    Bill R has a write-up somewhere in the archives about removing the steering wheel if you feel that's what you want to do. I've changed instrument lamps without removing the steering wheel. There's a write-up here on that too. I followed it but that was a year ago and I don't remember much about it. See what you can dig up before getting into all that.
    Paul
    May 2006
    NH
    I already tried to remove the cluster with the Steering wheel in place. No matter how far out i telescoped it and how i tried to tilt the cluster it would not fit thru.
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. where can I get a wheel cap removal tool?
    By bbig119 in forum 5 Series BMW
    Last Post: 05-21-2006, 11:52 PM
  3. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  4. What should a pick n' pull steering box cost?
    Last Post: 07-08-2005, 10:03 PM
  5. Wheel aligment/steering wheel question.
    By Don (Ireland) in forum 5 Series BMW
    Last Post: 08-25-2004, 06:04 AM
