The S38 decided to let the headgasket seep a miniscule amount of oil into the coolant. However slight it was, it had to be delt with, and the engine had to come out to perform the work. It's all back together now and better than it ever was.
While the engine was apart, it was an opportune time to replace the clutch, pressure plate, throw-out bearing and motor mounts, O2 sensor, distributor cap and rotor, gaskets and bolts everywhere. It didn't stop there as new hoses and belts also graced the newly cleaned and throughly gone through top end. The head was sent to the machine shop for hot tanking and valve grinding along with checking all the tolerances within specification. After 109k miles this S38-B36 engine still showed the crosshatch within the cylinder walls. The valve guides were still well within specification and the only thing replaced in the head were 4 exhaust valves, bringing it back to like new condition. I cleaned the tops of the pistons using a shop vac and masking off the area to reduce the chance of anything getting into the ring landings. It took 5 hours alone to get the piston tops like new again using plastic and wooden scrapers and Gumout.
The whole project took between 80-90 hours to complete. My fingers were sore for a week afterward. I learned plenty about the S38 and can say it was THE most complicated engine I have ever been inside. There was plenty of help, although I did every bit of the actual work by myself. You need to be focused in order to not miss anything, an interruption could cause a catastrophic mistake.
So first of all, I'm THANKFUL for my family and friends this Thanksgiving Holiday, and next....well, I'm thankful the S38 is back to better than ever conditon, ready for another 109k miles...
Enjoy!
JR
[IMG]
[/IMG]
