1211 DME Control Unit
1215 Air Mass Sensor
1216 Throttle Potentiometer
1218 Output Stage, Group 1
1219 Output Stage, Group 2
1221 Oxygen Sensor 1
1212 Oxygen Sensor 2
1222 Lambda Control 1
1213 Lambda Control 2
1223 Coolant Temperature Sensor
1224 Intake Air Temperature Sensor
1225 Knock Sensor 1
1226 Knock Sensor 2
1227 Knock Sensor 3
1228 Knock Sensor 4
1231 Battery Voltage/DME Main Relay
1232 Throttle Idle Switch
1233 Throttle Wide Open Throttle Switch
1234 Speedometer A Signal
1237 A/C Compressor Cut Off
1242 A/C Compressor
1243 Crankshaft Pulse Sensor
1244 Camshaft Sensor
1245 Intervention AEGS
1247 Ignition Secondary Monitor
1251 Fuel Injector 1 (or group 1)
1252 Fuel Injector 2 (or group 2)
1253 Fuel Injector 3
1254 Fuel Injector 4
1255 Fuel Injector 5
1256 Fuel Injector 6
1257 Fuel Injector 7
1258 Fuel Injector 8
1261 Fuel Pump Relay Control
1262 Idle Speed Actuator
1263 Purge Valve
1264 EGO Heater
1265 Fault Lamp (check engine light)
1266 VANOS
1267 Air Pump Relay Control
1271 Ignition Coil 1
1272 Ignition Coil 2
1273 Ignition Coil 3
1274 Ignition Coil 4
1275 Ignition Coil 5
1276 Ignition Coil 6
1277 Ignition Coil 7
1278 Ignition Coil 8
1281 Control Unit Memory Supply
1282 Fault Code Memory
1283 Fuel Injector Output Stage
1286 Knock Control Test Pulse
1444 No Fault Codes
If you cannot read them that means that you have a bad bulb or no buld at all. Older E34's don't have a check engine bulb wired.
1. Turn the ignition key on (without starting the car) and depress the accelerator pedal to the floor 5 times within 5 seconds.
2. The check engine light will remain lit for 5 seconds, blink off, light for 2.5 seconds, goes off for 2.5 sec. and will start flashing the codes.
3. Each code is separated by a 2.5 sec. pause. A 0.5 sec. blink then nothing means the end of the code reading. To read them again, depress the accelerator pedal 5 times again.
Clear the codes
1. Read the codes. At the end, make sure that the 1000 code (short blink and nothing) is present then depress the accelerator for at least 10 seconds.
2. To check, depress the accelerator pedal 5 times within 5 sec and make sure that the 1444 code (no fault stored) is present.
Car code display
With the key off, press in the OBC display reset button on the dash below the tach (the one that makes your readout disappear). Hold it in for 3 seconds and turn the key to position 2. Release the button, watch all of the car codings and then the final light show. That is the only way I want to see the tach go that high.
1995 540i Manual build 1/95
