Results 1 to 10 of 14
Thread: I don't post much...
    Jun 2005
    St. Louis, Missouri
    Default I don't post much...
    but I check in every other day or so to gain a little knowledge. Anyway I got into a bit of a fender bender the other morning on the way to work. Quoted $2700USD to fix. New hood and grille and some other bits.
    I was looking at getting some of the parts myself to save some cash and I was on BMA. Does anyone have an updated Discount code? I did a search and dotinfo, DOTINFO, and bimmer.info no longer work.
    The hood alone from body shop is $540!!
    Also does anyone know where I can find an OEM nose panel 51131978880 ('91 525)?
    Thanks and happy motoring
    May 2006
    NH
    Check your area for used auto parts delaers aka Junk Yards... you may find the matching parts needing no painting then again... good luck.
    1995 540i Manual build 1/95
    Long Beach, CA
    Quote Originally Posted by PeterInSTL
    1555
    Jun 2005
    St. Louis, Missouri
    Default Thanks
    Quote Originally Posted by uscharalph
    1555
    Thank you
    Jun 2005
    St. Louis, Missouri
    Default I will be searching
    Quote Originally Posted by Jehu
    I will check the yards out...but I will not get my hopes up.
    Jun 2005
    St. Louis, Missouri
    Default Opinions on Aftermarket Parts?
    I have found an aftermarket hood and nose panel, but I am hesitant to purchase them both. My dad was in the autobody business and I recall him hating the fit of most aftermarket parts. Has anyone had any experience with fitting aftermarket parts..times may have changed a bit?
    Buy used... check to see who has them... private and hopefully near you too so you can inspect and take it home with you. Much cheaper this way and all BMW parts.
    Nov 2006
    Mid-Atlantic, USA
    It's damn seldom a BMW gets totalled without front-end damage. Parted out by a repair shop when the cost of repair exceeds the value is a more likely scenario (cracked heads). I'm assuming you're in St. Louis; have you checked with the independent BMW shops in the area? The guy on Olive St. Road in U-City used to have a bunch of relics laying around. And remember, if you order from your local BMW dealer you won't have to pay shipping. The grille panel should be under $100 new, less if your dealer gives a BMW CCA discount or other discount. Never hurts to ask. Shipping body parts is an expensive pain in the butt.
    Honolulu
    Default Code
    try spece30
    nobody on here has said you just email patrick from bma and tell him your a member on here
  1. My First Post!!
    By BMWDriver in forum 5 Series BMW
    Last Post: 06-11-2008, 03:57 AM
  2. Last Post: Never
    By Macv in forum 8 Series BMW
    Last Post: 11-16-2006, 04:03 PM
  3. Can someone please post a pic of the Sun?
    Last Post: 03-05-2004, 11:42 AM
