ill probably be rolling in the 8-9 am range, ill be the gray shark rolling low, had so much crap in the car on the way up i was slapping the bump stops, if i had been thinking i would of bumped the rear spring seats up a couple spots
Originally Posted by
BMWCCA1
I think they just put the lines on the gauge at different spots. The sender is linear, the tank shape is not (smaller/narrower at the bottom); that last 1/4 goes fast. No different on an E28 or even a 2002.
Take a lap at Summit Point before you depart the area! I'll be passing through Winchester on my way to NY on Tuesday morning. We'll likely pass each other amid the trucks on I-81. I'll be in the white E34 with black-center fan-less M5 I-beam wheels. Probably won't hit Winchester until about 9am. Have a safe trip.
