Got a new member of the family, '95 318is. I need to change the rear wheel bearing, took everyhting off, got the collar nut off the hub and I can't remove the hub. Used a side hammer to remove it, still not even I think an increments did move out forward. What should I do, is there any other part I should look into that I didn't remove other than the collar nut? Thanks in advance guys!
