Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Brake Pads
    Behind the wheel of My Car
    Default Brake Pads
    More questions and another dip in to the wealth of knowledge on this board...
    I'm lookin to replace my pads and rotors
    Which would you guys recommend Axxis/PBR metal master dustless or Axxis/PBR Ultimate street pads?
    Just curious
    -Mike
    -Mike
    Chicago
    What do you want out of your brakes? What is your climate? What wheels do you have? Do you drive kids? Are you the only driver? What tires? Future upgrades planned?
    Sorry for all the questions, but anyone who comments on what fits you without asking you questions doesn't have the answers. So, lets learn more about what your needs are for the brakes.
    I can tell you what fits me. I wanted brakes that will work when cold, are not noisy, stop well, pads that don't wear out fast, pads that don't wear the rotors too fast, pads that can take the heat of spirited driving, a pad that didn't dust too much. I did not mention price.
    I chose the M5 brake upgrade with solid rotors for maximum friction area. I use Axxis Ultimates because of their performance in the cold and hot. They dust less than factory and the dust is more grey. I decided I wanted better stopping and less fade at the expense of some dust. I love my set-up. Perfect for the street and I have used them on the track.
    Here are some of my pad experiences:
    group
    Hawk HPS - need to be warmed-up to work well, not good for emergency stopping
    PBR/Axxis Deluxe - no dust, actually made noise, pad glazed, glazed pad glazed the rotor, didn;t stop as well as stock
    Textar - factory BMW pad, lots of dust that stains the wheels, good braking, very consistent, easy on the rotors
    Mintex Red Box - don't like, they seem to have some irregular wear, not good stopping, never use with cross-drilled rotors
    group
    Akebono - Like them as a stock replacement, good consistent stopping, no dust, no noise, easy on rotors
    Axxis Ultimates - Like them, dust just a little less than factory, great stopping cold, great stopping warm, less fading
    Track pads - Love how they stop at the track, they are so noisy and dusty, the stopping friction might suck your eyeballs out, wear out rotors
    Solid rotors are great and cheaper. The first 2 places to look at for heat resistance when braking are the pads and the brake fluid. So choose the pad and the price that fits you. I would suggest to anyone to flush the brake fluid. I like to use Ate Typ 200. It is the same as Super Blue, but I don't like how the Super Blue can tint the plastic reservoir blue. If you want to purchase brake fluid at the local parts store, then look for the Valvoline Synpower fluid. It is much cheaper than the Ate fluid and is very very good for the street. I like that I can get it whenever I want to. As with all brake fluid, it should be changed once a year.
    Brandon J
    As always Brandon I can rely on you for quality info after reading what you wrote I'm definitely going for the axxis ultimates. As far as rotors I was looking at TMS X-drilled.
    It seems redundant considering I already got the answer I was looking for but I might as well answer your quesions
    1- I want something that'll stop well in the cold as well as hot, no noise, I can't afford to go through rotors very often, little less dust would be good
    2-I have style 32's
    3-I have 3 younger siblings so yea I drive kids sometimes
    4-I'm the only driver
    5-Avon Tech M550 A/S
    6-Bilstein shocks, polyurethane control arm bush., LWFW, eventually S52 swap
    -Mike
    Honolulu
    Unless you're take'n the car to the track, I'd forget cross drilled rotors and just get a set of Brembos or ATEs.
    Quote Originally Posted by Blitzkrieg Bob
    Aren't brembos abit pricey? and don't the ATEs chew up pads?
    OK I'll be honest I also really like the look of X-drilled not to mention I drive as if I'm on the track...all the time so I want as much performance as possible even if I never use it, Its for piece of mind
    -Mike
    Aug 2005
    West Portland, OR
    I jsut got some Brembo rotors and some mintex pads, but I'll upgrade to Akebono when the weather gets better and I'll be doing more hard driving.
    EuroLux:. Private Detail
    Honolulu
    Quote Originally Posted by Sam-Son
    I dunno, the Brembos were the cheapest out here.
    Cross drilled? Bling Bling
    paint your calipers too
    Makin fun Bob?
    Seriously though I would also paint the calipers
    If you know where to find cheap brembos I don't suppose you'd like to pass that info along...
    -Mike
    Honolulu
    Makin fun Bob?
    Cheap may be realtive...I live in Hawaii where shipping a rotor is $$$.
    So, the local parts shop sells them at $70
    Hmm still like the TMS ones
    -Mike
  1. I Need Brake Rotors And Brake Pads!!!!!
    By BMW4LIFE in forum 5 Series BMW
    Last Post: 03-13-2009, 11:36 AM
  2. Brake pads
    By mamilapon in forum 5 Series BMW
    Last Post: 12-03-2006, 07:31 PM
  3. What brake pads are you using?
    Last Post: 07-04-2006, 04:02 AM
  4. brake pads
    By Incantation in forum 5 Series BMW
    Last Post: 08-14-2005, 05:56 AM
  5. Replies: 13
    Last Post: 03-11-2005, 09:25 PM
