Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: To add Sway Bars or Not?
    Sep 2007
    Hamilton Ontario
    Default To add Sway Bars or Not?
    Ok, I'm getting a Sach/Eibach suspension kit into this week from BMA. I plan in mid December to do the swap. I was wondering if at the same time its worth swaping the sway bars and end links out for some Racing Dyanmic (or other) stiffer sway bar.
    I have a Stock 525im m20.
    I was reading on bmw4life web page and it suggests removing the sway bar endlinks, so I was wondering if I should just swap everything while i'm under there?
    Opinions?
    New Mexico
    I'm always thinking "since I'm already there" Yes you should consider replacing what is worn. A car that is 17+ years old, yea go ahead a replace the sway bars and end links out. If you do a search you will find all the information you could ever want on suspension upgrades, also don't forget to check the E34 web site, http://www.bmwe34.net/E34main.htm Check both under upgrades and maintenance.
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
    T·O·R·O·N·T·O
    Have you tried the subframe inserts yet? racingking.ca
    Central NJ - USA
    sway bars
    ssk
    and stickey tires
    those are my top 3 mods in order of best/fav/most bestest
    i did them inthis order
    wheels/tires
    suspension
    ssk
    sways
    and i must say those sways made cornering much better
    Long Beach, CA
    What is SSK?
    Central NJ - USA
    short shift kit
    Long Beach, CA
    Quote Originally Posted by bahnstormer
    short shift kit
    No wonder I didn't know that, my BMW's got an automatic transmission. LOL!!!
    Sep 2007
    Hamilton Ontario
    Well i got the SSK, Suspension is here, Rims come after winter.
    Maybe i should look into some bars, are racing dynamics the best? Or are there better?
    Kentucky
    Quote Originally Posted by EngPhys09
    decide what size bar you want and get the cheapest one ... it's just a chunk of metal ... sure, it may be a pretty green color or whatever, but nobody is going to see it anyway.
    Central NJ - USA
    and honestly unless you like crawling under your car and playing with dirty grease you're not going to be adjusting the adjustable ones very often
    i set mine and liked it then when i changed wheel/tire sizes from 17 > 16 i changed again....
    so two adjustments in 2 years heheh
  1. i want to insall in my e32 sway bars from e34 M5
    By cae660 in forum 7 Series BMW
    Last Post: 01-07-2008, 01:38 PM
  2. sway bars - if u have them, please recommend
    Last Post: 03-16-2005, 07:33 PM
  3. sway bars
    By panzershreck in forum 5 Series BMW
    Last Post: 06-11-2004, 06:39 PM
  4. 94 540 Sway Bars
    By bam7276 in forum 5 Series BMW
    Last Post: 02-22-2004, 09:01 PM
