the temp should hit the middle line and pretty much stay with in about a needle width of it, i've gotten bad clutches out of the box but it's very rare with behr, after a run on the road after a few minutes of idling should get it mostly engauged, sometimes you need to turn off the ac to get the clutch to lock up as the electric is keeping the temp just below the fan's engaugenent point, several minutes of idling after a run should get you atleast a short howl when you blip the throttle, if not give it a few more minutes if the temp gauge is not climbing, the gauges are so dampened they are just about as useful as a dummy light
