Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: $775 Oxygen sensor in NC
  1. #21
    PA
    I know Could be a ton of **** I could diagnose but I am not there.
  2. #22
    V8 are pretty reliable car... I owned it for 8 years now... Vacuum leak can be the intake gasket (very common) and the idle control valve that is underneath that...
    MAF is a possibility if it shoot out that MAF or O2 engine code... but easily verified by testing the components.
    Other than that... I never had any problem.
  3. #23
    PA
    Question for the gurus - if I have her unplug the MAF - it should run better, if the MAF is misreading, right?
  4. #24
    Sep 2007
    Seattle, WA
    That's what I've heard as well. But don't run it for extended periods with the MAF disconnected, do that only for diagnosing a MAF problem.
    And yeah, have her take it to Korman.They know E34's better, and charge rather reasonable rates looking at the receipts of stuff they did to my car before I bought it.
    OEM O2's for the 530 list at $202/each. Even if they wanted 25% over list (seems that most dealers charge 20+% over list) that'd make $500 for a pair of O2's, and it certainly should cost $275 to install a pair of O2's. I've not seen the underneath of a 530 yet, but I'd imagine it's like my 540. Which would make it insanely easy to change them out.
  5. #25
    Reading, UK
    Correct, but it will take both the MAF and the O2 sensors (afaik) out of play... it wont give you a positive diagnosis of the exact component but it'll tell you there's something wrong with the metering rather than a mechanical fault.
    On the uk E39 boards they constantly bitch about BMW dealers diagnosing O2 sensors because of a vaccuum leak or MAF failure - the ECU will throw an O2 code whenever there's a metering fault somewhere. The only exception to this is when the MAF fails electrically, a la unplugged MAF.
  6. #26
    Dec 2006
    Try this: unplug the battery long enough to wipe the memory in the computer. Replug the battery and start the car. The car will run in closed loop for the first 5-10 minutes (don't know how long it lasts on the e34) and won't be reading any data from the MAF. If it runs properly....could be an indication.
    I used to do this on Ford V8's to run in closed loop when we suspected a MAF or other sensor problem.
  7. #27
    PA
    I have the dealer unplugging the MAF and running it and then pulling O2s and seeing if they're super fouled or not.
    Why am I telling the dealer how to fix this? Ugh.
  8. #28
    New Mexico
    [QUOTE=bubba966]Jon, send your sister here http://www.kormanfastbmw.com/
    Hey Jon.... Ray Korman in Greensboro is where I had my engine built (I know, I bought and did not build) in 2001, and I live in New Mexico. Ray has been very helpful to me over the years. I know it's frustrating to fix/diagnose anything form long distance.
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
  9. #29
    West Palm Beach, South Florida
    When its not reading sensor data, I'm pretty sure thats considered open loop.
    Closed loop is when it does modify based on output data.
  10. #30
    PA
    The Dealer is saying they're getting an "open circuit" fault on the one O2 sensor - I am letting them replace it (For like $300 ugh). I'll post when it's done...
  1. oxygen sensor 1 is bad which do i replace
    By 94530inh in forum 5 Series BMW
    Last Post: 11-29-2006, 08:34 PM
  2. which Oxygen sensor is #2 ??
    By lvngdead in forum 5 Series BMW
    Last Post: 06-10-2006, 01:46 AM
  3. Price of BMW oxygen sensor $725 AUD
    By F4Phantom in forum 5 Series BMW
    Last Post: 06-07-2006, 04:39 AM
  4. No oxygen sensor !!!
    By Ali in forum 5 Series BMW
    Last Post: 04-23-2005, 02:54 AM
  5. Oxygen Sensor
    By jbw535i in forum 5 Series BMW
    Last Post: 03-24-2004, 11:38 PM
