So my friend just bought a 2000 328i and it already has some problems.
1) When she hits the gas, more often than not there's a very high pitched
noise. Acceleration seems fine, just the noise.
Check belts or pully related components, AC, powersteering etc.
2) Engine service light came on and an Autozone guy diagnosed the air/fuel intake or something like that (I wasn't there for the whole conversation) but that's all his computer said. Possible reason for a small smell of burning after driving a while?
These models have a known fuel transfer pump issue when fuel is low or if you pull a .5 G or so in a turn. The transfer pump does not pick up fuel, runs a bit lean and throws an a/f code.
3) When the defrost and rear defrost are both on, the radio cuts out. Not the cd player.
Seems like a grounding issue, could not recall if the radio and rear defrost are on the same circuit called "accessories" check acc fuse for corrosion or sloppy fit.
4) After just receiving an oil change, the oil light comes on, bad oil pressure?
Have this checked ASAP, hope they added the right amount of oil in the engine, can't see oil pump failing after an oil change.
I know this is choppy but as it's not my car, I'm doing my best to get the issues across. I'm just wondering if you guys had some insight or quick fixes or guesses. Thanks for any help.
~Greg
