Results 1 to 4 of 4
Thread: Leaking Heat
    Jan 2005
    Williamsburg, VA
    Default Leaking Heat
    I've got a 1989 535i (about 210K miles) that is leaking heated air into the passenger cabin. With the air conditioning on, and all the dials toward "cold", I'm getting cold air through most of the vents, but am getting hot air from the small vents pointing toward the mirrors and through the foot vents.
    Not just "uncooled" air... it's definitely "hot" air. If I turn the A/C off and just circulate outside air, same thing. It has been doing this occasionally since early summer.
    If I turn off the blowers, I can still feel heated air leaking through the foot vents.
    Someone recommend tapping the heater control valve with a hammer. I'm not exactly sure that the HCV does, and I don't really like taking a hammer to things I don't really understand. If someone can explain this a little more, I'd be willing to give it a shot.
    Any ideas?
    Norman
    '89 535i, 225000 miles, family owned... Williamsburg, VA
    Honolulu
    The heater control valves are solenoid actuated valves that close with the power on, thus they tend to get stuck in the open position.
    I'd tray taking it apart and clean it rather than beating on it with a hammer..
    If the rubber membranes on the valve pistons are rotted and leaking coolant back into the solenoid, you'll need to but a new one.
    Jan 2005
    Williamsburg, VA
    Quote Originally Posted by Blitzkrieg Bob
    If the valve was stuck open, wouldn't there be heat coming from all the vents?
    Thanks!
    Norman
    Honolulu
    Quote Originally Posted by ElNormo
    Thanks!
    Norman
    Not always..depends on which set of vent flaps are open, and of course there are two valves controlling the two sides.
  1. Help! I have no heat.
    By goheel in forum 5 Series BMW
    Last Post: 12-06-2006, 04:38 PM
  2. -35c and no heat - HELP
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 11-29-2006, 07:50 PM
  3. Heat All The Time=Heat Valves?
    By slupregime in forum 5 Series BMW
    Last Post: 07-29-2006, 02:34 PM
  4. help me get heat
    By rbeaud in forum 5 Series BMW
    Last Post: 02-11-2006, 02:25 PM
  5. Over Heat
    By begeta50 in forum 5 Series BMW
    Last Post: 01-09-2006, 02:07 PM
