The groves will look exactly the same. HOWEVER, find the TDC mark on the pulleys and put them each at STRAIGHT UP. You will see the gap in the teeth on an non vanos is about 16 teeth to the RIGHT of straight up and the vanos wheel is about 10 teeth to the LEFT of straight up. The Vanos vs Non vanos are about 120 degrees away from each other based on the pulley. You need the crank wheel for whatever ECU you are trying to use.
