Originally Posted by
bimerguycw
Thanks for the feedback.
I feel like the root cause is the parking brake shoes since they are the most over-heated by bluish color but what is the proper way to get this system permanently corrected?
Do they get some grease/lube ike WD-40 or lite grease sprayed in to the places of openings or what. Bentley does not say much about these cables. I expect it can't hurt to spray a light lube into the park brake cable ends that are open, right?
I will check out the parking cable action tonight and see if it seems to bind or something.
I suppose if that's not it, then I'll go to the shoes' springs pull-back when handbrake released but that's kind hard to observe with the rotor on and it's on the inner surface. As said before I've checked for handbraking binding or point binding by rotating wheel with park brake off.
So, I guess it's intermittent in the parking brake system and I'll check it the best I can and maybe you have some definitive suggestions on this basic system.
