Results 1 to 10 of 10
Thread: Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Ottawa, Ontario, Canada
    Default Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    When I depress the brake pedal there's a "tapping" or "knocking" sound each and every time. Anything to worry about? There's no problem with the braking power, it's just the noise that has me worried somewhat?
    Blair...
    Mar 2007
    Liverpool UK
    I have a 'click' type noise that happens in intervals when i depress the brake pedal, its happened ever since i got the car and i've had no problems with it. The clicking seems to come from somewhere around the glovebox stry enough. It doesn't worry me at all however as the brakes work perfectly, and the noise is only audiable with the radio off and everything else silent.
    Others might be able to offer more advice if there is a problem, but you will need to provide more details - does the noise come from inside the car or outside? Is it more of a knock or a tap? Does it happen only when you press the pedal hard or soft, or all the time?
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Feb 2007
    New Forest, ,UK,
    Your release bearing is on the way out,OR get a friend to operate the clutch and look carefully at the front pulley, if it moves when the pedal is pressed then your thrust bearings are worn,strip down or Wynns and sell it.
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Barney Paull-Edwards
    Is this related to the brake problem?
    Feb 2007
    New Forest, ,UK,
    Sorry, wrong post!
    Australia
    If your car is RHD your brake light switch is behind the glovebox. On my 1988 car the brake light switch is above the pedal, but on my 1990 car the switch is behind the glovebox.
    Its quite common for the switch to click twice each time the pedal is pressed.
    Mar 2007
    Liverpool UK
    Thats good to know, thought i had problems then Barney! (I've done that before too! )
    And thanks Myles, mine is 1990 so must be the switch for me.
    Any help to you so far Angus?
    Yes, it's more of a "click" sound coming from above the brake pedal in the dash area EVERY time I hit the pdeal - soft or hard. I'll take the dash cover off today and see if I can pinpoint the cause. Again, the braking power is not impeded.
    Quote Originally Posted by e34.535i.sport
    The "clicking" sound seems to come from the small diaphram on the firewall that I guess is part of the brake booster (brake servo). Each time I depress the pedal I hear this annoying sound. Doesn't look like it's a separate part but part of the booster. Don't really want to replace the unit since the braking power is OK. Any other suggestions?
    Derbyshire, UK
    Quote Originally Posted by angusbn
    Endure. It's normal.
    1997 535i V8
  1. Replies: 0
    Last Post: 01-21-2008, 05:51 PM
  2. 530 "bucks" or "chugs" but driveshaft feels good....
    By 300k 5er in forum 5 Series BMW
    Last Post: 10-09-2006, 02:09 PM
  3. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  4. Replies: 5
    Last Post: 01-09-2006, 01:48 PM
