Results 1 to 10 of 14
Thread: Correct Tire Pressure?
    pa
    Default Correct Tire Pressure?
    Hi, The manual says 41 psi, but the tires say max pressure is 40psi. It does ride kinda hard with 40 psi. What should the pressure be if car normally drives with 2 adults upfront and 2 todds in the back? Thanks.
    Connecticut, USA
    I run 33 in the front 35 in the rear
    1990 Islandgrun 535iM Sedan
    3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
    pa
    Thanks, I'm also wondering why they would say 41 psi in the manual when most people don't run them that high?
    Nov 2006
    Mid-Atlantic, USA
    BMW switched to listing only maximum-load pressure suggestions years ago. Probably something having to do with some brain-trust loading the car down with five passengers and full trunk at 26 psi and suing over the result. I believe Euro-spec cars still show pressures for different load situations. Anyone care to share from their Euro model?
    I'd start around mid thirties all around and add more in the rear an necessary to increase understeer or more in front to increase oversteer (and vice-verse). That's the short version.
    Nov 2004
    Quote Originally Posted by BMWCCA1
    I don't have a Euro model...but the tire pressures given for areas outside the USA/Canada are given in my owners manual.
    BTW, the recommeded tire pressure is what the car's MFG suggests (which is what's listed in the owners manual and the label on the driver's door jamb).
    The tire pressure listed on the tire's sidewall is not a recommendation...but a WARNING by the tire MFG to NOT over-inflate the tire beyond what's listed. The MAX tire pressre is for safety reasons only based on the tire's construction & speed rating etc. The tire MFG can't really make a recommendation for tire pressure since they don't know what car (its weight, engine HP, torque, performance and handling, etc) the tire is going to be mounted on...they just make the tire to a specific safety and performance spec.
    Q
    95 525iT / 97 740iL
    Jul 2004
    Vancleave, MS
    Default what does US and Canada have to do with anything?
    ...unless we're saying that north american models weigh differnet so need different pressures....?
    i'm probably wrong, but run 39 front 41 rear 'cause I "think" that's what it says in my door jamb for 235/45 17inch tires....
    and i'm real happy with tirelife, handling, etc...at those pressures... BUT I think it's kinda noisy..don't know if that's related.
    Great Britain
    I don't know what the max load pressures are (the max pressure is for if you've got 4 adults and a whole bootfull of luggage) but I think the normal pressures are:
    Front: 33psi
    Rear: 36psi
    They both increase if fully loaded but the rears increase (not suprisingly) by the most.
    Mar 2007
    San Francisco
    hmm...my 1990 US-spec manual says 29/35 f/r for up to 4 people and 35/44 f/r for max load.
    Personally, I think 29 is a bit low for the front, since it looks really squat, so i like to go 32. But then i read somewhere that you need to maintain the differences in pressure f/r because it may affect the handling and dynamics of the vehicle in cornering...
    Sounds like bs, but then again, i like to play it safe. I knew someone who had a '00 323ci and it gave a whole slew of numbers. He just got fed up and put 32 all around. Worked fine for him...
    _______________________________
    1990 535iA Glacier Blue Metallic 114k
    Maryland, Virginia, D.C.
    I do 38 in front and 39 in the rear. It's just a preference of feel really. I like even and stable. If you are cornering on a track you don't do lower unless you like riding on your rims, and off into the sunset.
    Jul 2007
    Nr London UK
    I run mine at 35 all round - handles fine, its only normally got me inside and no luggage....
    The (UK) manual suggests 33 at the front and 35 rear.
    Who do I love Most - Wife, Kids or Car...
    Wife's always moaning, Kids always yelling...
    OK - The Car Wins!!
  1. Anyone know the correct A/C Pressure for 1995 E34 (R134a)
    By 2MuchTorque in forum 5 Series BMW
    Last Post: 09-14-2007, 07:44 PM
  2. Correct tire pressures for 235/45/17?
    By Jay 535i in forum 5 Series BMW
    Last Post: 09-05-2006, 05:07 AM
  3. Tire pressure
    By mitch2k in forum 5 Series BMW
    Last Post: 07-03-2006, 03:06 PM
  4. Correct tire pressure for Style 5 17's?
    By NielsGalan in forum 5 Series BMW
    Last Post: 09-13-2005, 01:18 PM
  5. Tire Pressure 101
    By Level8Drummer in forum 5 Series BMW
    Last Post: 03-31-2004, 11:22 PM
