Results 1 to 8 of 8
Thread: Unhooked the battery now won't start
    Nov 2006
    Norfolk, VA and Coats, NC
    Default Unhooked the battery now won't start HELP!!
    I unhooked my battery to reset the trans and when I went to hook it back up I heard a few beeps a constant clicking from under the dash. The red LED on the dash is blinking now too (looks like one for an alarm) and the car won't even try to start. WTH?! HELP!!!
    Behind the wheel of My Car
    You probably need the BMW alarm code. got to your local dealer or parts department and get the code from them
    -Mike
    Nov 2006
    Where would I enter such code? It's a '92 so it's not EWS.... Is there a way around this b/c I have class, and by the time I'm out, the dealer will be closed and I need the car tonight!
    Oldham, England
    Quote Originally Posted by Itsnotme1988
    Had similar. Connect + then -. If you battery isnt flat should be good to go
    Nov 2006
    I ONLY unhooked the negative....
    You enter it into the radio. Does it say code on the radio when the key is in the ACC position?
    -Mike
    Nov 2006
    Don't have a radio...
    Whatever it was, I figured it out....Well not so much figured it out as I got it to deactivate. It's an aftermarket something with 2 buttons on the bottom of the dash. Whatever it is, it's coming out SOON!
    Yeah I'd ditch that right quick
    -Mike
  1. HELP! Z3 battery died, jump-started, car won't start
    By brandilynd in forum Z3/Z4 Forum
    Last Post: 05-27-2017, 07:03 AM
  2. Disconnected battery for one hour, now E34 wont start
    By Murphy211 in forum 5 Series BMW
    Last Post: 06-01-2008, 09:23 AM
  3. Car wont start, is it the battery or altenator?
    By Calico_NC in forum 5 Series BMW
    Last Post: 04-25-2008, 10:02 PM
  4. 520i will crank, won't start. Bad battery?
    By JT520i in forum 5 Series BMW
    Last Post: 02-26-2006, 04:44 PM
