lower spings, bigger sway bars maybe more...
My '95 540 has the following option:
704 M SPORT SUSPENSION
What was included in this option?
-AJ
-Two E30s, an E34 and an E46-
1995 540i Manual build 1/95
Thanks --- does YOUR car have this option? Any pics of the front, if so?
-AJ
At least in the USA, that's the standard suspension used on the 540i 6-speed. The option number indicates the German factory code but it was included in the standard order deck for the USA. It included:
• firmer shocks
• larger front anti-roll bar (25mm vs. 23mm)
• larger rear anti-roll bar (18mm vs. 15mm)
• front suspension lowered 20mm
• rear suspension lowered 9mm
If anyone has the sway-bar set they've removed from their 540i 6-speed, I'd love to try it out on my lowered 525i.
http://home.comcast.net/~cpkver8/index.htmlOriginally Posted by Panzer Captain
All those and different seats,my TDS had it as I found out when I tried to replace the top mounts and discovered that they are different, shocks are 13mm at top,seats had sports thigh support but mine wore out.M5 front sway bar but had to put larger bar on rear as per thread advice.
Awesome - great post - exactly the info I was looking for! Where did you find that data?Originally Posted by BMWCCA1
-AJ
Sorry, meant that in Europe/UK you got M5 seats, 20mm rear bar fitted in ok after polybushing it,thrust arms have the rose joint not rubber bush as well from new ,as there were no records with my car of them ever having been changed and the original owner was anal about paperwork!
My 525i has option 704 "M tech suspension", but standard cloth (though heated) seats. I think the option is just the suspension.
1997 535i V8
Cool - do you have any pics of the car? I'm interested to see how low it is.Originally Posted by DaveVoorhis
-AJ
