Results 1 to 10 of 11
Thread: Jacking point collapsed...
    Mar 2007
    Liverpool UK
    Default Jacking point collapsed...
    Hey there, my RH front jacking point collapsed a while back and i've been using the trolley jack underneath for a while now but its getting on my nerves and i often find i need the second jack for other thingsa even when using jack stands. Does anyone know if you can buy the jacking points and change them or does it need welding or something? As i was using the BMW jack it made a noise and went from a __ shape to a ^ shape! All four are rusty so i need to do something really before i lose another one.
    Thanks.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    PA
    Jack the car up by the inner unibody frame rails
    Mar 2007
    Liverpool UK
    In lamens terms?! I'm not sure what that is sorry! Hey, i saw your cylinder head by the way... looks amazing. Looking into doing something similar wheni do the clylinder head gasket soon...
    PA
    Thanks.
    Get under the car right where the factory jack spot is. Now, look about 16" toward the center of the car. You will see a "beam" on either side of the car (one for each side). You can jack the car by that. Use a rubber guard on the jack or it'll chew up the under coating.
    Oldham, England
    Thanks.
    You might want to use a hetfy chunk of wood between your trolley jack and the box section too. Spreads the load and helps stop it from squashing
    PA
    eh never had a problem squashing it just tearing up the rubber coating.
    Oldham, England
    Strange. Never had a problem with tearing up underseal
    PA
    Your car doesn't squat hard under acceleration :P
    Oldham, England
    You are right. I have springs that stop that happening
    drill a small whole the size of a straw< purchase a two part metal bond eposy gun and a couples tubes of glue chaulk and fill the hollow space above you jack point> this glue will dry hard as steel and reinforce thestress point!
    john blouin Jblouin@remaxcrown.ca
  1. Jacking your BMW
    Last Post: 09-04-2008, 10:16 AM
  2. jacking question
    Last Post: 01-07-2007, 11:24 PM
  3. Jacking Procedures
    Last Post: 11-11-2006, 12:01 PM
  4. jacking points
    By broadie777 in forum 5 Series BMW
    Last Post: 07-03-2006, 06:19 PM
  5. Gas tank collapsed
    By Rina120 in forum 5 Series BMW
    Last Post: 02-26-2004, 12:54 PM
