Results 1 to 10 of 19
Thread: Front suspension.
    Feb 2007
    New Forest, ,UK,
    Default Front suspension.
    Ok, tried most springs in tester and come to the conclusion that Rip-Off is the word.Two makes(well known) were purely cut down standards, one looked as though they has been half cut then snapped. Put six different springs on a home made tester calibrated with a known 2.25 in x300lb spring,nothing came near, either to advertised rate or suitable rate.So nuts to that, am going to make my own.Problem,2.25 in springs and thread tube will not fit over 56mm OD leg. Next plan is to put the leg tube in a CNC lathe and machine a thread down the leg in order to fit then I can make my own set up.2.25 springs in 10" or 12" length are $38 here so can afford to experiment,the question for the experts is: anybody done this before, and is there a better way?????????????!!!!!!!!!!!!!!!!!!!!!
    Oldham, England
    Default A Better Way?
    Dont have the kit so my solution would be something like this:
    http://www.kellysearch.co.uk/gb-product-87416.html
    Feb 2007
    New Forest, ,UK,
    Read that thanks but comes back to same problem,nobody make a sensibly priced coilover kit for an E34,springs cheap but coil-over kits use 2.5 springs which are bloody expensive! Cost wise I can get the tubes machined for £35 and the platforms and locks for £28,cheaper than springs for sure!
    TC535i Guest
    Interesting... I wonder what my eibach ERS springs test at?
    Feb 2007
    New Forest, ,UK,
    Not going to name names BUT, a german spring tested , sold as 25mm lower and "stiffer" was exactly the same wire diameter and coil size, tested out at 178 and 192lbs, put those on the wrong way round(no indication on springs) and the car would handle like a bus.
    Dec 2006
    UK
    A mate uses this place and reports good things www.dfaulknersprings.co.uk/
    Feb 2007
    New Forest, ,UK,
    Thats a fluke, its where my springs have come from for years, also highly recommended.
    Could you list the spring rates for us?
    Wellington,New Zealand
    springs are (relatively)cheap to get wound to any spec you want
    Gone but not forgotten
    Feb 2007
    New Forest, ,UK,
    I am writing to all the European suppliers this w/e to ask for info. When I have info I will publish results but US suppliers may alter specs I guess. All of the ones I aquired were different rates which is why I posted this to ask if anybody had evolved the best "fast road" rate.
  1. e34 front oil suspension
    By dwaynos in forum 5 Series BMW
    Last Post: 05-19-2008, 12:24 PM
  2. Front suspension on 39...
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 12-23-2006, 12:41 PM
  3. Need a Suspension/Front End Rebuild
    By cableface in forum 5 Series BMW
    Last Post: 06-20-2006, 09:07 AM
  4. Front Suspension Advice
    By av8r in forum 5 Series BMW
    Last Post: 01-17-2006, 02:16 PM
  5. Front suspension help needed
    Last Post: 03-02-2005, 12:04 PM
