The car's alternator is responsible for charging the battery. No additional charging should be required.
You can charge the battery manually with a charger to see if it takes and holds charge.
I'll gues your alternator is on it's way out. Often replacing just the voltage regulator portion is all that is required, a big saving over the cost of a complete alternator.
