Results 1 to 7 of 7
Thread: seems irrational -sway bar links
    Lexington, Kentucky
    Default seems irrational -sway bar links
    This weekend I replaced my original rear sway bar links at 144,000 miles. Rubber was bit cracked was all I saw wrong.
    Today, the car seems to corner flatter and ride a bit tighter/more controlled. Also a small clunking noise from the right rear seems to be gone. I also lost weight too!!
    Seriously, can this small change make this big a difference? TIA
    Jun 2007
    Cheshire CT
    Lost weight? I can only assume this is either a diet reference or a joke... if you're on a diet and losing weight, congratulations! (how'd you do it?) If it's a joke... hahahaha.
    Philly, PA
    Actually, loose sway bar links make a huge difference. Replacing them is pretty noticeable. And the clunk is almost 100% definilty the links.
    Lexington, Kentucky
    It was a joke
    Lexington, Kentucky
    I am trying to replace as many of the rubber suspension parts as I can. I just never thought this small repacement would make that much of a difference. Now on to the sub-frame bushings.
    Jun 2007
    Cheshire CT
    Yeah, I'm actually looking for a dirt cheap parts car for a full subframe to rebuild. I want to do it all and be able to just slap it into the car in one shot.
    Quote Originally Posted by Bin_jammin
    I did that with my "spare" e34. Worked pretty well, was able to get it all sparkly clean and do all the bushings.
    I used 535 bushings but I think the m5 bushings are the same fit but a different part number, making me think they could be stiffer and possibly a nice BMW upgrade. Trailing arm bushings are a bear to swap out, hard to get a good angle on them and they're in there with a few hundred tons worth of press fit .
    Robin
    72 Chevy K10
    01 E39 M5
  1. Meyle HD sway bar links
    By Bo525i in forum 5 Series BMW
    Last Post: 06-19-2013, 10:35 AM
  2. Rear sway bar Links-Help!
    Last Post: 09-23-2007, 03:58 PM
  3. Symptoms of bad sway bar links
    By mbogosia in forum 5 Series BMW
    Last Post: 12-30-2005, 03:52 AM
  4. Adjustable sway bar links from mye28.com...
    Last Post: 12-06-2005, 10:41 PM
  5. sway bar links brands?
    By shragon in forum 5 Series BMW
    Last Post: 10-26-2005, 12:02 PM
