My registration document says:
Number of formaer keepers: 3 - so that makes me the 4th (1994 525)
If not, how far down the line are you? Judging from the receipts I have, I'm the sixth.
Who do I love Most - Wife, Kids or Car...
Wife's always moaning, Kids always yelling...
OK - The Car Wins!!
2nd owner - bought it from the original owner's son.
Second, bought from a gypsy, never towed a caravan,allegedly.`95 525TDS. Anyone know when production stopped?
i bought my 5er from auction imports from japan...have no idea on how many owner it has, nevertheless don't really care for as long as its in top shape and drives like a champ and does not really give me headaches as much as my friends 1999 e39Originally Posted by indierthanthou
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
2nd owner. I purchased it from a Volvo/Cadillac dealer. It was owned by an older couple (wife's car) who traded it in on a New Volvo SUV. Almost perfect condition cosmetically. Bit of deferred maintenance which as been more than taken care of. Way too much to listOriginally Posted by indierthanthou
However, the car is better now then when I bought it (72,000 miles later).
2nd owner 1990 525i, purchased in 1994 with 33,000 from dealer in Albuquerque, NM. I had the M20/Turbo done in 2001 by Ray Korman and I now have 42,000miles on it with no major issues.Originally Posted by indierthanthou
M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip.
Garrett Turbocharger, adjustable waste gate, intercooler, oil cooler
Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm The boost comes on nice an early (1100 to 1500rpm) very strong and smooth through RPM curve. I have not adjusted the boost it seems to work well where it is. New redline @ 6900rpm.
Peak Hp. gain 95 @ 4750 to 5000rpm ~ 246hp
Peak TRQ. gain 116 @ 3250 to 3500rpm ~269ftlbs
Dinan intake, Dinan exhaust, Dinan 17”wheels 245/40/17, Dinan stage III suspension, UUC short shift, Rear wing, M mirrors. Shock tower stressbar
Just completed replacing the drive Belt, tensor, camshaft seal & 0-ring, Distributor cap, Rotor, coolant, water wetter, water pump, thermostat, water hoses, front wheel bearings, center bearing, flex disk, vibration damper, centering sleeve, Replaced differential, engine & transmission oil (Redline). Front and rear brake pads and rotors, brake fluid, front & rear sway bar links, rear trailing arm link (dog bones), Sub frame bushing plates (Racing king). New Tires Yokahama AVS ES100.
Not a bad car for 17 years old......
M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
Cant find the log book but I think I'm about 10th. I also think 1-9 were lazy b...s judging by what I've had to put right
Nope, 3rd owner. Bought from the 2nd owner a year ago who bought it CPO at 20k miles.
Very possible that I'm the 3rd owner. Guy before me had it since 98 and 61000 miles up until last month. Before that ... I don't know.
