That metal line is the tranny cooling line. You're probably dripping coolant from the upper hose down onto the fitting for the metal line, otherwise you may be leaking either from the brass fitting pressed into the plastic tank, or the tank may be cracked at the fitting. Clean with a decent solvent and check again.Originally Posted by bigtisas
