since youll be in there I would suggest replacing all hoses and belts, should be good for another 100k. I only removed the passanger side block drain and flushed the old stuff out 3 times til it was clear, make sure the heater is on hot and full speed. When your done flushing you should add 1/2 the amount coolant first as there will be a lot of water trapped and if you instal it pre mixed your final mixture will be too weak. System is self bleeding and you will usually have to top it of 2-3 times over the next few times you drive the car.
Edit: should be able to locate the metal housing at BMAparts or autohauz along with the hoses and belts.
Originally Posted by
charlie
Hi guys,
I want to do a total cooloing system r&r before the winter. I have a new water pump, t-stat, and coolant. what else do you guys suggest doing? anyone have a parts list? where do you buy the replacement metal t-stat housing?
TIA
