Sorry but your fan must be replaced. I recently replaced my condenser to which the fan is attached. I removed the front bumper which required peeling back the rubber about half way and removing the 4 bolts holding it on. Next I unplugged the side lights, outside temp sensor and fogs. Withthe bumper removed you might be able to remove the fan without removing the condenser but I doubt it. I also took the 2 clips holding the radiator off and lifted it out of the way. this gave me a little more room to operate. Plan on buying new radiator retaining clips.
