Is it jumping violently?
Get the transmission oil changed for a good quality well known brand, and see if it keeps doing it.
If it keeps doing it it's probably the synchromesh on first has collapsed...
1990 535
Manual Transmission
Shift Kit
120,000 miles
Recently, the transmission jumps out of first gear. If I shift 1 to 2 and back a few times, it almost always works. Thinking it is shifting fork.
What are my options? Used, rebuilt, transmission shop, etc.
Also make sure engine and transmission mounts are good - excessive movement can cause jumping out of gear on some cars. I have not had this happen with BMWs specifically though.
Bill G
Check the linkage to make sure it isn't being blocked.
Nearly 100% that it is the shift forks.
Had the problem with my 318is, got a used trans from a junk yard, it poped out of different gears. Ended up rebuilding the original.
Found some good info on the Metric Mechanic site.
Warren
88 325iX
91 318is
95 525iT
