Thread: front end "rattle" noise ....
    Dec 2005
    VT
    Default front end "rattle" noise ....
    so I put in new control arms which took care of the shaking. I did the lower ones last year.Now I still get a kind of rattle from the front end when I drive on rough surfaces. What could that be? Wheel bearings, but it's not a grinding noise? I have close to 100K on the car.
    Thanks .......
    Albuquerque, NM
    Have you checked the swaybar links? If not that, then it could be the pads rattling in the caliper:
    My son's e34 has noticable wear and corrosion/pitting on his calipers where the ends of the pads register. I felt quite a bit of slop up & down when putting in new pads & rotors a couple weeks ago. His has the same rattle you describe and it sounds like it's coming from right at the wheel. His upper strut bearing/mounts and sway bar links are tight. Loose pads are the only other thing I can think of.
    I'm not quite sure how to remedie it other than getting new calipers and/or a different brand pad. Easy enough to check by temporarily sliding a shim in there and seeing if the rattle goes away.
    gale
    Dec 2006
    I have a leaking front shock, that causes the same rattle you are describing on my car.
    Jan 2007
    it could even be bad sway bar bushings.....
    Jon M
    '88 E34 535i 5spd
    Iceland
    Dec 2005
    VT
    Thank you for the reply, I'll check it out ..... it's more like a clunk when I hit a pothole or other unevenness in the road. It's difficult to explain ....... are there any other bushings or such in the wheel area other than the ones I already replaced? (upper and lower arms)
    thanks again ........
    a clunk could be the strut collar being loose.
    Quote Originally Posted by fsteyer
  1. Odd 'flapping" noise up front
    By Peterlech in forum 5 Series BMW
    Last Post: 03-29-2007, 03:57 AM
  2. "VANOS rattle"
    By Tut in forum 5 Series BMW
    Last Post: 04-08-2005, 06:23 PM
  3. cruise control actuator making "noise" before car starts....
    Last Post: 11-05-2004, 09:36 AM
  4. Fix rattle "Double Sunroof" on '94 Touring?
    By DVDke in forum 5 Series BMW
    Last Post: 06-18-2004, 11:49 AM
