Results 1 to 7 of 7
Thread: How to remove small triangle glass window on rear door?
    Default How to remove small triangle glass window on rear door?
    Hi,
    My car was lock from inside while having nice time on the beach.
    As a result i deciced and broke the small glass window at the rear LHD door, without realizing that it is very very difficult to replace it.
    Is there any hint on how to replace the small triangle glass? What would be the steps?
    My car is 1988 e34 520i.
    thanks in advance,
    rahman
    Rahman in Kuala Lumpur,
    1988 520i M20B20
    1988 730i M30B30
    1982 323/6 M20B23
    1980 316
    1984 GPZ550
    baton rouge, loserana
    yea thats the hardest side glass to change and for some reason the one people wanna break, the plastic trim on the inside of the divider between the twl glasses pops off revealing 3 + screws for the outer trim, which then can be pulled off, that whole aluminum divider piece comes out once you get the screws top and bottom, it's been a while since i changed one but i am fairly sure you need to pull the main glass out to get the divider out, it's one of those things that you gotta work at, nothing needs to be cut or broken
    Actually, i broke the window glass myself. I thought it's easier, but i was wrong.
    Man, it's still pending.. even the junk yard guys gave up to pull out the triangled glass window...
    rgrds,
    1988 520i M20B20
    1988 730i M30B30
    1982 323/6 M20B23
    1980 316
    1984 GPZ550
    Aug 2005
    West Portland, OR
    Oh dude, you're going to be finding glass pieces in your car for like 10 years.
    Vacuum out under the rear seats, lots of it hides in there.
    EuroLux:. Private Detail
    Sep 2004
    Northern Europe
    Good thing you hadn't double locked the car. Wouldn't have been nice to find that after you had broken the window the door couldn't be opened from the inside either.
    Nov 2006
    bay city michigan
    Quote Originally Posted by nsbone_1988_520i
    Hi,
    thanks in advance,
    rahman
    Took off two windows from my parts car to sell to someone in california. Then I call the guy up and tell him not to buy them because its impossible to replace without trim and window intact. You have to buy factory window with trim intact and then install. Clips are buried in the molding and cannot be dislodged without screwing it up. I lost 100 bucks on a sale and now doors are no good because windows are missing. It may be cheaper to buy whole door then to buy window from bmw.....good luck
    Nov 2006
    bay city michigan
    Sorry I may be misleading you. 1988 model window may be different then 1989-95........But if car is E34 chances are you are screwed.
  1. Rear Door Glass Operation
    By 93 525 Paul in forum 5 Series BMW
    Last Post: 07-28-2008, 11:43 PM
  2. remove rear side window switch?
    Last Post: 12-17-2006, 08:30 PM
  3. clips f. rear door window switches, where to get?
    Last Post: 09-23-2005, 07:47 AM
  4. rear door small sunshade fix
    Last Post: 08-05-2005, 11:19 AM
  5. Replies: 0
    Last Post: 08-05-2005, 10:00 AM
