Thread: will stock bmw bbs rims from an 840 fit?
    Aug 2007
    Pittsburgh, Pa
    Default will stock bmw bbs rims from an 840 fit?
    i found a good deal on a set of 4 of the stock bmw bbs wheels and tires off a stock 840.
    will they fit? ne1 have pics w/these on there?
    thanks
    Dave
    Victoria, Australia
    Yes they will; just confirm that the offsets are 20
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    should say the offset amongst the numbers under the cap.
    Quote Originally Posted by t.wak
    95 E34 530I V2.34
    Jul 2007
    Long Island, NY
    I believe the offset is more like 15mm, isn't it?
    -AJ
    -Two E30s, an E34 and an E46-
    You can put from 13 to 23 mm offset on the e34, 20 being the optimum offset. It all depends on your tire selection, the closer you goto 23 the less wide of a tire you can use, because it will rub your suspension. I cant stress enough how important it is to find the exact tire size for your application.
    I thought the BBS wheels are 16x8" with a +10 offset.......also you can only use a 225/55-16 tire......and if they do make a 17x8" BBS wheel I am not aware of it. But a 17" fitment would use a 235/45-17.....otherwise the center-bore is correct and they will work.
    1995 540iM Alpine White/ Lt Silver Grey 84k
    1992 535iM Black/Lt Silver Grey 132k
    1990 535iM Glacier Blue/Blue 206k
  1. Anyone interested in trading stock rims?
    By boardburton in forum 5 Series BMW
    Last Post: 11-11-2006, 09:47 AM
  2. Looking for one stock e34 rim
    By ilya in forum 5 Series BMW
    Last Post: 08-11-2006, 11:36 AM
  3. Tire sizes for stock rims
    By jnmip in forum 5 Series BMW
    Last Post: 11-15-2005, 10:06 AM
  4. Need a stock 95 M3 amp
    By Unregistered in forum 3 Series BMW
    Last Post: 05-21-2004, 10:09 AM
