Results 1 to 7 of 7
Thread: Humming sound just after ignition is switched on
    Aug 2005
    Default Humming sound just after ignition is switched on
    Car started making a humming sound, as if something is grinding against something else, just after the ignition is switched one. This lasts for only a couple of seconds then stops. Pump is already noisy, but this sound seems to come from under the front hood. You can actually feel it, not just hear. Sometimes this also happens when the engine is running. It could be happening more frequently, but while driving you won't hear it.
    1994 520i with M50 engine, manual transmission and air conditioner.
    VIN: GG45422
    aux pump pulsating and transmiting vibrations to the front??
    May 2006
    Antwerp, Belgium
    Or ICV? I get the humming sometimes on 'electrics and ignition on' before I crank. Sometimes also when I tap the throttle over idle and let it fall back to it.
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    Aug 2005
    Is there an auxiliary fuel pump?
    VIN: GG45422
    May 2006
    Antwerp, Belgium
    Quote Originally Posted by t_marat
    Not up front. I remember reading about some BMW models having two fuel pumps but those were in the rear. One for fuel pickup and filtering, the second for pressurising the fuel lines to the engine.
    I'm thinking it could well be the aux water pump even if I had the symptom when blipping from idle. Does it sound like the sound travels from the front-left to the dash and sides?
    2008 audi A3 1.9tdi
    PA
    you're definitely hearing the aux water pump
    Aug 2005
    Will an auxiliary water pump ran even if the heater is off, that is temp regulators set to minimum level and blower off?
    VIN: GG45422
  1. Weird humming noise coming from (PIC)
    By Monastie in forum 5 Series BMW
    Last Post: 07-11-2007, 07:11 PM
  2. Loud humming sound front wheel driver's side
    By takumidrift30 in forum 5 Series BMW
    Last Post: 08-30-2006, 02:15 AM
  3. Replies: 9
    Last Post: 07-31-2006, 10:17 PM
  4. ::.. Elephant sound after ignition off
    By Qube in forum 5 Series BMW
    Last Post: 06-17-2006, 12:02 PM
  5. Humming after shutoff
    By cappy in forum 5 Series BMW
    Last Post: 05-21-2004, 11:05 PM
