I believe it's the outside ambient air temperature sensor for your OBC display.
Look here at item no. 10 - Sensor outdoor temperature.
1994 540i.
This is a closeup of the front driver side of the car. This specific "cable" is only on this side (there's no identical one on the passenger side).
Is it for the airbag or something? Where does it go? IN the bumper?
Or am I just retarded?
And for the sake of future reference, where is the airbag sensor?
That's the temperature sensor used by your OBC to display the exterior temperature.
1997 535i V8
Outside temperature sensor.
1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
Excellent. Thanks.
Anyone know where it plugs?
The car is completely put back together and finished, but I'm taking the front end apart this weekend for a few minor adjustments, and I remember I just rolled this up and tucked it away the last time (cause I didn't know what it was, and I was just testing all the other parts for fit).
It doesn't plug. It basically gets clipped to the radiator support panel, at least on my 535 that's the way it is. Zip tie it somewhere the wiring won't rub and leave it alone at that.
Sounds easy enough... will do, and thanks for all the QUICK responses.Originally Posted by Bin_jammin
Look at your bumper.... notice the panel that has a hole in it on the driver side but not the passenger side? Look at the little hole in that panel.... Thats where it goes on the 540s
Mine also mounts on the front bumper behind this hole.
Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
VIN Decoder | Online ETK | E34 Bible
outside air temp sensor, on all e34's in the same place, right next to the driver's side foglight
